18 x 2.15" Rolled Edge Rim Black - V-Twin 52-0785 - OEM 43004-35 - Big Twin 1935-1980
SKU 52-0785
$209.99
$209.99 - $209.99
$209.99
OEM #: 43004-35, 3940-35
Replica black powder coated front or rear 18 inch X 2.15 inch steel wheel rim. This is a WM type rim with welded beaded construction.
Features conventional bead construction with a bead width of 2.20 inch. Center valve stem hole measures 8.5mm. The rim features a 360° full press-weld located at the bead area which gives the rim a flatter profile. *NOTE: Full roll edge rim with weld on side. *NOTE: This is a WM inchBritish style rim order as required per your specific build. *NOTE: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
1936-1939 EL
1941-1980 FL
1937-1939 UL
1935-1952 WL
