16 x 3.00" Rear Rim Drop Center - V-Twin 52-0699 - OEM 43006-40
SKU 52-0699
$99.99
$99.99 - $99.99
$99.99
OEM #: 43006-40, 3940-40
Raw rear 16 inch X 3 inch wheel rim. Rim is drop center design and 40 spoke holes with large valve stem hole.
This rim has a large side valve stem hole is 15mm and accepts rubber valve stems *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
1940-1965 FL
1940-1965 FXR
