1-Hole Crank Pin - V-Twin 10-0686
by Eastern
399 ENTRIES 🎟️
399 ENTRIES 🎟️
New Old Stock inch 1-hole crank pin is original Army Surplus used on 45 inch models.
You must align oil feed in flywheels with crank pin. OEM uses 2 different flywheels so hole location may differ. This crank pin includes two oil feed holes to fit both the early and later flywheels. The distance measured from the edge not including the threads is 2.516 inch *NOTE: Must order nut kit separately.
1937-1973 G
1937-1952 W
