WR 45 Brake Pedal Zicad Plated - V-Twin 49-1510
Reproduction of WR WLDR and WRTT cast iron stubby rear brake pedal is zicad plated.
This is an ingenious design which incorporates the pedal and bell crank into one. This mounts to rear footboard rod and pivots on it. Use the long rear brake linkage to connect to the rear brake. *NOTE: Also available is the right side 1 piece WR brake pedal. This allows the footboard side strap to be removed for a weight saving. Brake pedal connects directly to the rear brake rod. *NOTE: Zicad is a dull shade of zinc similar to cadmium.
- Axle Diameter: 3 inches
- Axle Width: About 1 inches
| 1936-1952 | WL |
