54-1/2 Zinc Speedometer Cable - V-Twin 36-0616 - OEM 67028-37
SKU 36-0616
499 ENTRIES 🎟️
499 ENTRIES 🎟️
OEM #: 67028-37
Zinc transmission drive speedometer cable with 5/8 inch top nut and male nut for Servi-Car models.
Speedometer cable has a length of 54-1/2 inch with a 10mm outer diameter and a zinc plated flexible metal housing with hex nut fitting. Cable has a male fitting at the speedometer end for original speedometers and the rear wheel drive end is female nut. For aftermarket speedometers use 1962-1973 style cable.
1937-1961 G
