Shovelhead 74 Short Block - V-Twin 10-2009
SKU 10-2009
Original price $5,409.99 - Original price $5,409.99
$5,409.99
54099 ENTRIES 🎟️
$5,409.99 - $5,409.99
$5,409.99
54099 ENTRIES 🎟️
Assembled and tested for oil pressure.
74 inch Short block is shipped fully assembled. Unit features Sifton oil and breather assembly stock stroke flywheel Timken bearings stock cam properly installed with a matched pinion and cam gear with Torrington bearing. Assembly is supplied with a cam cover and chrome lifter blocks are fitted with standard tappets. Tappets will accept a hydraulic lifter unit or solid conversion kit sold separately. Sprocket shaft is correct length to use with 1965-69 FL transmission with a mid length mainshaft. Left side case will accept tin stamped inner prmary cover. Not for use with electric start. Manufacturer's Statement of Origin is supplied.
1966-1969 FL
