Kreem Gas Tank Liner - Kreem 1010
by Kreem
SKU 41-0110
Kreem #: 1010
25 CASES
Kreem gas tank liner is designed to prevent leakage from hairline cracks and seam pinholes by coating the tank's inner surface with a fuel resistant.
Not for plastic or fiberglass tanks. Before using the Liner remove valve and petcock from gas tank then remove tank from motorcycle. Stop all outlets. Liner comes in 16 fluid ounces. Prep cleaner sold separately.
  • 1-5 Gallon tanks use 1 bottle.
  • Larger tanks use 1 quart per 20 gallon of tank capacity.
0 All
