Kreem Gas Tank Combo Kit - Kreem 1210
Kreem #: 1210
25 CASES
Our gas tank prep kit from Kreem products is a three part combo pack and will help stop leaks and prevent corrosion.
Kit includes one 16 ounce bottle of tank wash/cleaner one 8 ounce bottle of tank prep and one 16 ounce bottle of tank liner. Kreem will seal and protect prevent rust. and stop leaks from pinholes and hairline cracks on new gas tanks. It is resistant to alcohol and gasohol and will withstand most octane boosters. Most gas tanks will require one pint of Kreem per three gallon capacity. Recommended for all new tanks to prevent rusting.
- You can remove Kreem by using Acetone or Methyl ethyl keyton e available at most paint stores. Fill about half full sea l the tank and leave for about 24 hours drain and inspect.
- Sealing over old Kreem Liner inspect the tank if no peeling wash tank out with degreaser rinse tank for 2 minut es using 1 pint of acetone. Re-coat tank with Kreem Liner.
- Sealing over old Kreem Liner if tank is peeling wash with a degreaser rinse tank for 2 minutes using 1 pint of acetone re-apply after using Tank Prep A and B part.
- To thin Kreem tank liner use methyl ethyl keytone or acetone
| 0 | All |
