Harley Big Twin & Sportster Illuminator Turn Signal Module - Namz ILL-01-B
Illuminator module allows turn signals to be used for running and brake lights without losing their turn signal function. This is the plug and play type. Turn signal module has a built in load equalizer III works with your stock OEM turn signals with stock 1156 single function Incandescent bulbs custom Incandescent small turn signals Halogen and LEDs runs mixed front and rear. Also features optimized modulation technology for distinct intensity difference from run to turn to brake modes and easy to follow instructions & connector plugs included. Compatible with security systems. For use on models with OEM 6 pin tail lamp connector and wires. Installation instructions (PDF). Fits 1986-1996 Harley Dyna, FXR, Softail, Sportster, and Touring models.
Namz #: ILL-01-B
| 1986-1990 | FLT |
| 1986-1996 | FXD |
| 1986-1994 | FXR |
| 1986-1996 | FXST |
| 1986-1990 | XL |
