Harley Big Twin & Sportster Illuminator Turn Signal Module - Namz ILL-01-A
Illuminator module allows turn signals to be used for running and brake lights without losing their turn signal function. This is the plug and play type. Turn signal module has a built in load equalizer III works with your stock OEM turn signals with stock 1156 single function Incandescent bulbs custom Incandescent small turn signals Halogen and LEDs runs mixed front and rear. Also features optimized modulation technology for distinct intensity difference from run to turn to brake modes and easy to follow instructions & connector plugs included. Compatible with security systems. For 1997-up FLH 1996-up Softail & 1997-up FXD & 1999-2003 XL models. Installation instructions (PDF). Fits 1996-2013 Harley Dyna, Softail, Sportster, and Touring models.
Namz #: ILL-01-A
| 1997-2013 | FLT |
| 1996-2012 | FXD |
| 1997-2010 | FXST |
| 1999-2003 | XL |
