16 Star Hub Wheel Cover Set Chrome - V-Twin 49-0299
Chrome 16 inch wheel cover set for star hub wheels with rubber side valve tube stem for rear rigid mechanical drum brake or Duo-Glide front drum for front application.
Full wheel cover set has inner diameter of 221mm to accept brake drum. 4 screws and nuts supplied for fastening. Right hand spacer must be ground or turned down to fit into cover. NOTE: For mechanical rear drum and Duo-Glide front drum applications.
- Inner Diameter: 8-7/8 inches
| 1937-1953 | EL |
| 1941-1966 | FL |
| 1958-1971 | G |
