16 Rear Wheel Cover Set Chrome - V-Twin 45-0365 - Big Twin 1973-1984
SKU 45-0365
$159.99
$159.99 - $159.99
$159.99
16 inch chrome rear wheel cover set fits between disc rotor and sprocket for 1973-1984 FLH spoke wheel models.
Set is fastened with 5 bolts. Wheel cover will fit rims/wheels with Side Valve tube type standard width 3-1/2 inch rims only. When used with a center valve tube the rim cover must be removed to be filled with air. For hubs with 27mm offset on each side. *NOTE: The customer must drill a 5/16 inch hole for the valve stem. Use 1/8 inch drill for pilot hole after locating the inch5 inch mounting holes. Use with suggested metal stem inner tube. The hubs are drilled 7/16 inch on the disc rotor side and 3/18 inch on the sprocket side. For center valve use tubeless tire valve stem to fill hole for steel or ally hub applications. *NOTE: Front wheel must have (2) 5-hole flanges. *NOTE: Side Valve stem hole is 18.5mm for metal stem tubes with nut. For installation of wheel cover set on 1973-1984 FL Rear wire rotor side wheels cover with pentagon shape hole and 5 lug bolt holes will be secured with 5 7/16 inch x 14 carriage bolts. (This is the rotor side.)
  • *Full wheel cover for 3.0 x 16inch Drop Center rims only.
  • Suggested to use with 5.10 x 16inch Tube Side Valve Metal Stem.
  • Suggested to use with 16inch Rear Wire Wheel Cover Set Chrome.
1973-1984 FL
1973-1984 FX
