Harley Big Twin & Sportster 16 Front Wire Wheel Cover Set Chrome - V-Twin 45-0378
SKU 45-0378
$189.99
1899 ENTRIES 🎟️
$189.99 - $189.99
$189.99
1899 ENTRIES 🎟️
16 inch chrome front wire wheel cover set includes 1 cover with a hex hole and the other chrome cover with a 4.1 inch round hole. Set is for pentagon shaped hub flange wheels. For single disc brake wire spoke wheel. Wheel cover will fit rims/wheels with side valves. *NOTE: When filling center valve tube applications cover must be removed. *NOTE: The customer must drill a 5/16 inch hole for the valve stem. Use 1/8 inch drill for pilot hole after locating the inch5 inch mounting holes. Hex hole side has 4 mounting holes used as a template to drill the other cover with the 4/1 inch round hole. *NOTE: The side with the lug bolt holes install first the side with the pentagon hole align with valve stem and install. The last step is to install (4) screws to hold both covers together in place. *NOTE: Side Valve stem hole is 18.5mm for metal stem tubes with nut. Fits 1973-1999 Harley Big Twin, FX (Super Glide), Sportster, and Shovelhead models.
  • *Full wheel cover for 3.0 x 16inch Drop Center rims only.
  • Suggested to use with 5.10 x 16inch Tube Side Valve Metal Stem.
  • Suggested to use with 16inch Front Wheel Cover Set Chrome.
  • Suggested to use with Wheel Cover Stainless Steel 6-32 Bolt and Nut Kit.
1973-1984 FL
1973-1999 FX
1986-1999 XL
