Stelling Handlebar Throttle Spiral - V-Twin 49-1371
Stelling short pull type spiral.
Short version for Hellings and Flanders style bars. Flander's spiral is shorter than the standard Harley type version for spring fork handlebar with a chrome spiral sleeve. *NOTE: Use the inchpull inch type handbar spirals to use braided pull type cables. Use the same outer cable as required for each type of handlebar. Carburetor return requires spring loading.
- Length: 4-3/8 inches
| 1941-1948 | FL |
