Offset Spring Fork 1 Handlebar Chrome - V-Twin 49-0896
SKU 49-0896
$179.99
$179.99 - $179.99
$179.99
Standard type chrome Spring Fork handlebar with offset with 1 inch bar ends for external inchfast inch throttle applications. The forged triple tree is welded in place.
For use on stock style Spring Forks with an offset stem. *NOTE: Center forging surface is not polished before painting or plating **NOTE: Forged tree has holes on each side for wiring or cables. ***Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
  • Width: 34 inches
  • Height: 5 inches
  • Depth: 11-1/4 inches
1946-1948 FL
1946-1948 UL
