Mousetrap Clutch Booster Assembly Kit - V-Twin 22-0702
Mousetrap clutch booster assembly kit for 1952-1967 Big Twin models
For use with tin inner primary models only; 1936-1952 EL and 1941-1964 FL. Clutch release arm is available separately. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs. **NOTE: Spring included is chrome black spring available separately. Booster arm is zinc plated and booster bracket is natural cast aluminum.
- Suggested to use with Clutch Release Arm Parkerized
| 1952-1964 | FL |
