Throttle By Wire Twist Grip Sensor - V-Twin 36-1885 - OEM 32310-08A - Twin Cam Touring 2008-2013
OEM #: 32310-08A
Throttle by wire twist grip sensor allows installation of stock or accessory handlebars.
Hardwired like OEM CVO version from the sensor to the main connection on the harness. Terminals are pre-installed. Includes 6 position connector for installation after the harness is routed through handlebars. Be sure grip is mated snugly against the gear drive to prevent damage. After installing new twist grip sensor set the right handlebar switch to run. Turn ignition switch on you will hear the fuel pump cycle on and off. Wait 30 seconds and turn ignition switch off. Wait for turn signals to flash for 30 seconds. Repeat this process 2 more times. This will reset the throttle body and make it in sync with new twist grip sensor.
- Long Wire Length: 38 inches
- Short Wire Length: 26-1/2 inches
| 2008-2013 | FLT |
