Handlebar Throttle Spark Control Spiral - V-Twin 49-0087 - OEM 3312-42
SKU 49-0087
$69.99
$69.99
$69.99
$69.99
$69.99
$69.99
OEM #: 3312-42, 56246-35
Chrome Spring Fork handlebar throttle spiral is pull type.
To activate the linkage on the Keihin Bendix carburetor you are required to do the pulling and the linkage will open to the throttle. *NOTE: Spiral uses 1-1/8 inch inner diameter grips on both sides.
- Length: 6 inches
- Width @ Wide Side: 1-1/4 inches
- Width @ Small End: 1 inches
- Direction of the internal spiral is counter-clockwise
| 1936-1940 | EL |
| 1941-1948 | FL |
| 1935-1952 | G |
| 1937-1948 | UL |
| 1935-1936 | VL |
| 1935-1952 | WL |
