Harley Big Twin Stelling and Hellings Riser Set - V-Twin 49-1927
SKU 49-1927
$209.99
2099 ENTRIES 🎟️
$209.99 - $209.99
$209.99
2099 ENTRIES 🎟️
Stelling & Hellings style riser set will accept 1 inch handlebars and will fit with an original spring fork handlebar cut down from stock. Set is natural finish cast stainless steel. The Stellings and Hellings riser set are reproduced accurately from investment cast stainless steel. Riser mounting will require a stock set of handlebars to be cut down so there is a short stub remaining to accept the risers the bar stub will be 1 inch. The riser set is offset to mount to the bar end studs to make the riser stems parallel when installed. V-Twin offers a top tree with stubs as an alternative to cutting down a set of Spring Fork bars. Risers are cast of stainless steel machined to specs and then polished. you will need the stock handlebar cut down to 11 inch overall width. Please measure twice cut once!. Fits 1936-1957 Harley Flathead, Knucklehead, and Panhead models.
  • Height: 3-1/2 inches
  • Suggested to use with Hex Type Handlebar Riser Bolt Set.
  • Suggested to use with Spring Fork Inline Rise Clamp
  • Suggested to use with Offset Spring Fork Top Triple Tree.
1936-1942 EL
1941-1948 FL
1936-1957 G
1936-1948 UL
1936-1952 W
