Harley Riser Adapter Insert Set - V-Twin 37-1016 - Big Twin 0+
Riser adapter insert set has 3/4 inch-16UNF thread on the bottom portion. The set has 1/2 inch-13UNC internal thread. NOTE: Use a 3/4 inch-16UNF tap to make threads in the 1 inch outer diameter tubes on stock or replica V-Twin spring fork rear legs. Use to attach 1/2 inch-13UNC threaded risers to threaded inserts. Universal fit for most Harley applications.
- Requires tapping holes in the rear Spring Fork leg with a 3/4inch x 16 tap.
