Harley 5 Solid Billet Chrome Riser Set - V-Twin 26-0598
If you like the feel of your handlebars and just want to position them differently consider this straight riser set for use with a full 1-1/4 inch diameter bars at the riser mount section. Solid billet chrome riser set features a 5 inch rise for 1-1/4 inch diameter bars with 1/2-13UNC mounting threads. Set includes two mounting bolts and right and left sides. Risers will accept full 1-1/4 inch bars only these are bars in which the clamping area is 1-1/4 inch in diameter. *NOTE: For 1 inch handlebars you must order the riser adpater sleeve spacer set separately. Universal fit for most Harley applications.
- Inner Diameter: 5 inches x1-1/4 inches
- Suggested to use with 1-1/4inch Handlebar Riser Adapter Sleeve Spacer Set Chrome.
- Suggested to use with 1-1/4inch Handlebar Riser Adapter Sleeve Spacer Set Black.
