Harley Dyna 5 Fat Riser Set - V-Twin 26-0742 - OEM 59783-08 - Big Twin 0+
If you like the feel of your handlebars and just want to position them differently consider this fat riser set for use with a full 1-1/4 inch diameter bars at the riser mount section. Risers will accept full 1-1/4 inch bars only these are bars in which the clamping area is 1-1/4 inch in diameter. Fits 2008-2017 Harley Dyna models.
OEM #: 59783-08, 56895-08
- Height: 4-1/2 inches
- Suggested to use with 1-1/4inch Handlebar Riser Adapter Sleeve Spacer Set Chrome.
- Suggested to use with 1-1/4inch Handlebar Riser Adapter Sleeve Spacer Set Black.
| 2008-2017 | FXDF |
