Harley 4.1 Fat Riser Kit Black - V-Twin 26-0052
SKU 26-0052
$149.99
1499 ENTRIES 🎟️
$149.99 - $149.99
$149.99
1499 ENTRIES 🎟️
This riser features a one-piece base that is designed to be used with internally wired 1 inch handlebars and provides a skirt that conceals the wirings exit from the bar. Includes riser matching handlebar clamp and the clamp hardware. Riser base is drilled and tapped for 1/2 inch-13 threaded bolts. *NOTE: List of OE additional parts are from existing motorcycle. *NOTE: May require the separate purchase of additional components. Universal fit for most Harley applications.
  • ° OE cup washer (upper) (install flat side up) (2)
  • ° OE Bushing (4)
  • ° OE Spacer (2)
  • ° OE cup washer (lower) (install flat side down) (2)
  • ° OE flat washer (2)
  • ° OE split lockwasher (2)
  • ° OE ground wire
  • ° OE internal tooth lockwasher
  • ° OE rear mounting screw (2)
  • ° Front clamp screw (2)
  • ° Rear clamp screw (2)
