Harley Big Twin 3 Flanders Style Riser Stems - MCM 66101
Riser stems are chrome plated steel and have a 3/4-16UNF thread to screw into spring fork rear legs. The spring fork rear legs must be threaded to accept risers. Use tops and bushings from existing Flanders risers. Requires use of 3/4 inch-16UNF tap. Installation of these riser stems requires tapping of the rear leg tubes to 3/4 x 16 for mounting. Fits 1936-1957 Harley Flathead, Knucklehead, and Panhead models.
MCM #: 66101
- Bar Diameter: 1-1/4 inches
- Pullback: 2-1/2 inches
- Suggested to use with Chrome Replica 5-1/2inch Flander Riser Set.
- Suggested to use with #25-1946 Flanders Riser Set.
| 1936-1948 | EL |
| 1941-1948 | FL |
| 1936-1957 | G |
| 1937-1948 | U |
| 1936-1952 | W |
