Harley 1-1/4 Riser Kit Black - V-Twin 26-0701 - Twin Cam Softail 2007+
If you like the feel of your handlebars and just want to position them differently consider this short steel riser set for use with a full 1-1/4 inch diameter bars at riser mount section. Risers will accept full 1-1/4 inch bars only these are bars in which the clamping area is 1-1/4 inch in diameter. *NOTE: For 1 inch handlebars you must order the riser adapter sleeve spacer set separately. Fits 2007+ Harley Softail models.
- Thread: 1/2 inches -13
- Suggested to use with 1-1/4inch Handlebar Riser Adapter Sleeve Spacer Set Chrome.
- Suggested to use with 1-1/4inch Handlebar Riser Adapter Sleeve Spacer Set Black.
| 2007-UP | FXST |
