Stelling & Helling Speedster Handlebar Chrome - V-Twin 49-0727
Stelling & Helling 8 inch speedster handlebar is for offset Spring Forks and features a chrome finish.
Jack Tracey asked Stelling & Helling to develop handlebars that were 4 inch taller than the original inchcomfortable inch Speedster. Horn and dimmer switch mount holes are on the left side. Order internals and pinch bolts separately. Must use with extended wiring and cables. Order short spirals separately requires two per bar. Grips must be cut to length for this installation. Parkerized end plugs included. NOTE: Bars have shortened grip area to accept the short Hellings type spirals as used on the Stellings bars of the late 1940's. Bars include screamin plugs. Features brazed construction as original! *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
- Suggested to use with Handlebar Spiral Set.
| 1946-1948 | EL |
| 1946-1948 | FL |
