4 Stretch Image 4.0 Gallon Gas Tank - Wyatt Gatling 011664
Wyatt Gatling #: 011664
Gas tank has a left side petcock opening. It features flush lower mounts and includes pop up cap.
This Wyatt Gatling tank has a 4 inch stretch to the back of the tank which does not affect the mounts. The underside of the tank will accept 1/8 inch National Pipe Thread hose barb fittings for the fuel crossover line. Check the tank for flaws and fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. Check petcock opening making sure the petcock can be easily installed. Petcock fitting should be masked or plugged during painting for easy installation of the petcock. Front hole center to center measures 3-1/4 inch rear hole center to center is 3 inch and front to back center to center is 9-1/4 inch. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
- Top Length: 22.5 inches
- Bottom Length: 21.5 inches
- Rear Width: 3-1/8 inches
- Front Width: 11.5 inches
- Rear Height: 2.5 inches
- Front Height: 9 inches
- Front Tunnel Height: 4 inches
- Rear Tunnel Height: 2 inches
- Tunnel Length: 22.5 inches
- Overall Length: 23-1/2 inches
- Suggested to use with Smooth Style Gas Cap Vented.
