Carburetor Conversion Fitting Kit - Pingel 62071 - OEM 62842-00 - Twin Cam 2000+
Pingel #: 62071 · OEM #: 62842-00
Chrome carburetor conversion fitting kit converts models equipped with a fuel injection system to a carburetor system. Kit accepts 22mm hex nut type petcock.
Tank fittings replace the stock fittings allowing the use of the valve to feed the carburetor. *NOTE: Must order petcock fuel valve separately.
| 2002-UP | FLHR |
| 2002-UP | FLHT |
| 2002-UP | FLHX |
| 2000-2017 | FLST |
| 2002-UP | FLT |
| 2000-2017 | FXD |
| 2000-2017 | FXST |
