SV Linkert Carburetor Bean Pot Bowl Kit - V-Twin 35-1720
Linkert carburetor bowl kit features a bowl with a inchbean pot inch style with a built in drain screw. This bowl is fitted with a hex cap nitrophyl float and float arm. Includes carburetor overhaul kit.
Kit includes assembled needle and seat gaskets and stainless steel screw kit. *NOTE: For final float arm installation the center prong should have.003 inch clearance bewtween the prong and the head of needle in order for the arm and needle to move freely. After final assembly the mount screw must be affixed with loctite or any other adhesive. *NOTE: For all Side Valve engines including K-model engines.
| 1936-1957 | G |
| 1937-1948 | U |
| 1930-1935 | VL |
| 1936-1952 | W |
