Complete OHV Linkert Carburetor Float Bowl Assembly - V-Twin 35-1460
Complete Linkert flat top float bowl assembly is for Overhead Valve models. Assembly includes a natural finish bowl nitrophyl float float arm needle and seat bowl nut gaskets and patch. Features the drain screw provision.
Kit is assembled and includes all required parts. Kit has been tested for smooth operation. The needle features a rubber tip. Customer must install per service manual. *NOTE: For the float arm installation the center prong of the float arm should have.003 inch of clearance in order for the arm and needle to move freely. Assembled by our Motor Shop. Float screws are sealed for long service life.
| 1936-1952 | EL |
| 1941-1965 | FL |
| 1952-1956 | K |
