Replica Linkert M74 Carburetor - V-Twin 35-0082 - OEM 27130-48
SKU 35-0082
Original price $649.99 - Original price $649.99
$649.99
$649.99 - $649.99
$649.99
OEM #: 27130-48, 1134-48A
Replica M-74 Linkert carburetor is assembled and includes a complete replica linkert carburetor body with a 4 bolt mount flange with full brass construction.
All linkerts are supplied in natural finish or painted black as original. 1-1/2 inch carburetor assembly includes the top throttle arm assembly installed and with a 1-5/8 inch venturi. *NOTE: Must order related parts and hardware separately. Throttle arm supplied is specifically for 1949-1965 FL models. ***NOTE: Sold outright. No exchange necessary. All parts are brand new including the nitrophyl inchunsinkable inch float. Assembled by the V-Twin Motor Shop in New York!
  • Raise float level 1/8inch. Increase the size of the small idle slot hole behind the plug by.005inch from.020inch to.025inch. Cut baloney slice on top of main jet and face toward motor for
  • more spray.
  • *NOTEinch M-74 jet goes toward the high speed needle the other holes get plugged.
1948-1965 FL
