Replica Keihin Carburetor Assembly - V-Twin 35-1738 - OEM 27155-76A
SKU 35-1738
$389.99
$389.99 - $389.99
$389.99
OEM #: 27155-76A
Replica 42mm butterfly type Keihin carburetor accepts all replacement OEM components. Complete carburetor assembly includes updated needle and jet with fuel passages.
Keihin carburetor is single cable design. Related components available separately. *NOTE: This Keihin carburetor is made with V-Twin MFG.'s exclusive tooling. *NOTE: Requires throttle cable only. Must select correct throttle cable for type of throttle housing.
  • Suggested to use with Black Throttle Cable with 90° Elbow Fitting for 1976-1981 single cable operation.
  • Suggested to use with Keihin Carburetor Diaphragm Pump.
  • Suggested to use with Black Throttle Cable with 90° Elbow Fitting for 1981-1996 single cable operation.
1976-1980 FL
1986-1992 FLST
1986-1992 FXST
1976-1987 XL
