OKO Performance 1-7/8 Shorty Carburetor Black - V-Twin 35-1049
OKO performance shorty carburetor is painted black and accepts S&S bolt pattern air filter assemblies. It has a relocated accelerator pump nozzle for increased throttle response.
This is the R-2 version of the OKO type replacement carburetor. OKO shorty carburetor accepts S&S air cleaners Shorty E carburetor components and rebuild parts. All pieces interchangeable. Air cleaner mount bolt configuration is S&S inchE inch type. *NOTE: 1-7/8 inch = 47mm. We suggest using Loctite for proper installation. Use with dual cable throttle/assembly cable. *NOTE: Must order manifold separately. *NOTE: The main jet installed is #190.
- Fuel Inlet: 90°
