OKO 47mm Shorty Carburetor Kit - V-Twin 35-1830 - Ironhead 1966-1977
SKU 35-1830
$369.99
$369.99 - $369.99
$369.99
Performance 47mm shorty carburetor with natural finish. Kit will accept S&S bolt pattern air filter assemblies. It has a relocated accelerator pump nozzle for increased throttle response. Uses flat sealing ring for manifold.
Includes Shorty Carburetor Air Snoot with door. This is the R-2 version of the OKO type replacement carburetor. OKO shorty carburetor accepts S&S air cleaners Shorty E carburetor components and rebuild parts. All pieces interchangeable. Air cleaner mount bolt configuration is S&S inchE inch type. *NOTE: Requires carburetor support bracket to mount to the air cleaner and stud between the cylinders. Additonal holes in the air cleaner backing plate may be needed for mounting. *NOTE: 1-7/8 inch = 47mm. Use with dual cable throttle/assembly cable. *NOTE: The main jet installed is #190. *NOTE: Kit is supplied with brand type intake manifold and band seal set. Kit fits with the inchstepped inch conversion rings if used on a pre 1978 application (o-ring). Snoot is not an air cleaner but for the air intake only. We suggest using Loctite for proper installation.
1966-1977 FL
1973-1977 FX
1966-1977 XL
