OKO 47mm Shorty Carburetor Kit - V-Twin 35-1175 - Ironhead 1978-1984
SKU 35-1175
$299.99
$299.99 - $299.99
$299.99
Performance 47mm shorty caburetor with natual finish. Kit will accept S&S bolt pattern air filter assemblies. It has a relocated accelerator pump nozzle for increased throttle response. Uses flat sealing ring for manifold.
This is the R-2 version of the OKO type replacement carburetor. OKO shorty carburetor accepts S&S pattern air cleaners Shorty E carburetor components and rebuild parts. All pieces interchangeable. Air cleaner mount bolt configuration is S&S inchE inch type. *NOTE: Requires carburetor support bracket to mount to the air cleaner and stud between the cylinders. Additonal holes in the air cleaner backing plate may be needed for mounting. *NOTE: 1-7/8 inch = 47mm. Use with dual cable throttle/assembly cable. *NOTE: The main jet installed is #190. Chrome round mesh air cleaner available separately. *NOTE: Order air cleaner separately.
  • Required to use with Retro OKO Shorty Carburetor Parrs Kit Brass if used with custom air cleaners because the enricher will have to be changed.
1978-1984 FL
1978-1984 FX
1978-1984 XL
