OHV Linkert Carburetor Float Bowl with Alloy Finish - V-Twin 35-0490 - OEM 27371-36
SKU 35-0490
$79.99
$79.99 - $79.99
$79.99
OEM #: 27371-36, 1267-36A
Alloy finish Linkert carburetor float bowl has flat top and provision for drain screw hole.
Includes linkert carburetor float pivot pin with caps for float pivot arm. Order pivot arm separately. Needle valve seat opening is milled flat and sealed by carburetor body after assembly.
1936-1952 EL
1941-1965 FL
