OHV Linkert Bean Pot" Float Bowl Kit - V-Twin 35-1286
SKU 35-1286
$119.99
$119.99 - $119.99
$119.99
Linkert float bowl kit has a bowl with a milled flat top is for Overhead Valve models. The bean pot linkert bowl has extra capacity for long wide open throttle sessions. The bowl is milled flat at the needle seat opening.
Larger diameter adds 1.45 cubic inches to hold additional fuel. Extra capacity for racing applications has external bow hex cap. Has 9/16 x 20 hex plug at needle valve opening. Fits all brass linkert carburetors for additonal fiel capacity! NOTE: Original inchBean Pot inch linkert bowl design was developed by Tom Sifton Motorcylce Products. *NOTE: Float bowl with drain screw includes unsinkable black nitrophyl linkert float with our unique 1 piece float arm in brass for smooth action. Pivot pin with two caps stainless steel needle with matching brass seat assembly installed. Needle valve seat opening is milled flat and sealed by carburetor body after assembly.
1948-1952 EL
1948-1965 FL
0 Special
