Linkert Nitrophyl Carburetor Float - Sifton 76878B
Sifton #: 76878B
This M model float is our exclusive tooling for an exact Replica fit and function. Molded of nitrophyl material which is fuel resistant.
NOTE: Includes bolt and nut to attach to float arm. This float will not leak or swell and is impervious to modern fuel. This is the same weight as the orginal and used the same settings. For use with all round-bowl series M Linkerts. Arm is not included. Includes genuine linkert M float. For the float arm installation the center prong of the float arm should have.003 inch of clearance in order for the arm and needle to move freely. **NOTE: Sold as a pack of 5. Includes brass screws and shouldered nut.
| 1936-1940 | EL |
| 1941-1965 | FL |
| 1937-1948 | UL |
| 1933-1934 | VL |
| 1933-1952 | WL |
