Linkert Float Bowl Parts Kit - V-Twin 35-1264
SKU 35-1264
$84.99
$84.99 - $84.99
$84.99
Linkert float bowl parts kit includes a float bowl nut with an internal drain hole stainless steel nozzle spring nitrophyl inchunsinkable inch float and matched needle and seat.
For use on other parts of the Linkert carburetor kit also includes bowl hex nut with built in bowl screw gaskets and stainless steel screw kit. Features an internal drain hole to drain water out of the bowl. *NOTE: For the float arm installation the center prong of the float arm should have.003 inch of clearance in order for the arm and needle to move freely. *NOTE: Must order float bowl separately.
1936-1952 EL
1941-1965 FL
1936-1952 G
