Linkert Carburetor Bowl Lock Nut with Drain Zinc - V-Twin 35-0368
SKU 35-0368
Linkert carburetor bowl lock nut and drain is zinc plated and is for use with all brass Linkert bowls. The nut and drain allows water to drain without removing the bowl.
This special float bowl nut with a 1/4 inch allen drain screw allows the draining of condensation and water that settles in the bowl. We've paired this with a stainless steel nozzle spring and crush gasket.
1936-1952 EL
1941-1965 FL
1937-1957 G
1937-1952 W
