Linkert Carburetor Bowl Lock Nut with Drain - V-Twin 35-0374 - OEM 27375-29
SKU 35-0374
OEM #: 27375-29
Linkert carburetor bowl lock nut and drain is for use with all Linkert bowls. The nut and drain allows water to drain without removing the bowl.
This special float bowl nut with a 1/4 inch allen drain screw allows the draining of condensation and water that settles in the bowl.
1936-1952 EL
1941-1965 FL
1937-1957 G
1937-1952 W
