CV Carburetor Enrichment Assembly - Sifton 77424 - Evolution 1993+
Sifton #: 77424
CV adjustable choke cable eliminiator features full 360 brass construction. For use with CV Keihin carburetors.
This unit will replace the original choke cable on CV Keihin carburetors. This unit features all metal construction body is machined brass. Evolution and Big Twin cam installation will require manifold spacing to allow choke knob to clear fins. Overall length is 2 inch with choke knob extended. Includes new plunger and spring order spacer separately. Easy to install just thread in and go!
- Carburetor may have to be spaced out at least 1inch.
- CV Carburetor will require a spacer between the manifold and carburetor to allow clearance for this CV Carburetor Enrichener.
| 1993-UP | FL |
| 1993-UP | FX |
| 1993-2017 | FXD |
