CV 40mm Carburetor Natural - Sifton 30009 - OEM 27731-04 - Sportster 1984-2006
by Sifton
SKU 35-0611
$259.99
$259.99 - $259.99
$259.99
Sifton #: 30009 · OEM #: 27731-04
Natural finish 40mm CV carburetor is for XL models and is an accurate reproduction of the Venerable Keihin CV carburetor.
Includes 1.6 main jet and 0.42 slow jet. Must order related components separately: cables manifold choke cable and air cleaner is not included. *NOTE: Order jet assortment separately. Carburetor includes bracket for dual push-pull throttle and idle cable installation. Early applications will allow use of a single pull throttle installation. *NOTE: This CV carburetor is made with V-Twin MFG.'s exclusive tooling in Taiwan. *NOTE: Recommended installation components are as folows: CV carburetor adapter flange carburetor base gaskets handlebar throttle cable assembly single carburetor support bracket carburetor choke cable bracket and 40mm V-Twin CV intake manifold seal.
  • Main Jet: 1.6
  • Slow Jet: 0.42
  • OEM #27731-04 - Carburetor | OEM #27114-88 - Main Jet | OEM #27100-88 - Needle Jet | OEM #27171-89 - Slow Jet | OEM #28026-04 - Jet Needle | OEM #27320-04 - Cable Bracket
  • Suggested to use with CV Carburetor Adapter Flange.
  • Suggested to use with Carburetor Base Gaskets.
  • Suggested to use with Handlebar Throttle Cable Assembly Single.
  • Suggested to use with Carburetor Support Bracket Zinc Plated.
  • Suggested to use with Carburetor Choke Cable Bracket Chrome.
  • Suggested to use with 40mm V-Twin CV Intake Manifold Seal.
1984-2006 XL
