Bendix Cast 38mm Carburetor - Bendix 013731 (EACH) - OEM 27155-72B - Ironhead 1972-1976
Bendix #: 013731 (EACH) · OEM #: 27155-72B
Cast 38mm carburetor is fixed type. Carburetor features a cast finish with a single cable operation.
Carburetor includes choke accelerator pump and built in return spring. Carburetor can also be used on 1957-1985 XL with modifications. *NOTE: Mainfold and gaskets available separately. *NOTE: May require additional jetting for proper performance.
- Suggested to use with Alloy Intake Manifold O-Ring.
- Suggested to use with V-Twin Carburetor Flange Gaskets.
| 1972-1976 | FL |
| 1972-1976 | FX |
| 1972-1976 | XL |
