40mm CV Carburetor Assembly Natural - V-Twin 35-0715 - OEM 27490-04 - Sportster 1988-2006
OEM #: 27490-04
40mm bare CV carburetor is an accurate reproduction of the venerable Keihin CV carburetor and features a natural finish body and silver top. Shipped complete as pictured.
Carburetor includes bracket for dual push-pull throttle and idle cable installation. The carburetor floating bowl features the overflow system with hose. Early applications will allow use of a single pull throttle installation as the throttle idle bracket does not allow enough clearance for Shovelhead Panhead and Knucklehead engines. CV reproduction carburetors have been manufactured with new exclusive tooling by Ultima (Midwest Motorcycle Supply) a division of V-Twin Manufacturing. *NOTE: Recommended installation components are as follows: CV carburetor adapter flange carburetor base gaskets dual cable carburetor support bracket carburetor choke cable bracket and 40mm V-Twin CV intake manifold seal.
- Suggested to use with CV Carburetor Adapter Flange.
- Suggested to use with Carburetor Base Gaskets.
- Suggested to use with Handlebar Throttle Cable Assembly Single.
- Suggested to use with Carburetor Support Bracket Zinc Plated.
- Suggested to use with Carburetor Choke Cable Bracket Chrome.
- Suggested to use with 40mm V-Twin CV Intake Manifold Seal.
| 1988-2006 | XL |
