Harley Wyatt Gatling Touring Torque Linkage System - V-Twin 51-1609 - Big Twin 1993-2008
Touring torque linkage system features a black finish and will fit all Touring models with no modifications necessary to install unit. This unit will eliminate the lateral movement while still allowing the Iso mounted factory design of the inchfloating inch drive train to move vertically as designed through connecting the rear of the transmission case to the frame. Kit utilizes an isolation link with a urethane plunger so there is no contact between the frame and engine transmission assembly therefore reducing vibration. Installation instructions (PDF). Fits 1993-2008 Harley Touring models.
| 1993-2008 | FLT |
