Harley Replica Durfee Girder Spring Fork - V-Twin 49-1392
Chrome Spring Fork unit is a recreation of the original 1975 Durfee Girder Spring Fork and features a 1 inch stem and 3/4 inch axle holes. Stem must be spaced for each neck length for links to be parallel for proper taper spring function. Triple trees must be spaced so fork links are parallel. Large spacer for under top tree additional spacers may be required on 1 inch outer diameter stem. The top and bottom link holes measure 5/8 inch and the length from the bottom of the lower tree to axle position measures 980 cm = 36 inch. Will requires the use of a 7-3/4 inch axle with 3/4 inch diameter. The axle spacing measures 6-3/16 inch outside to outside and 5-3/16 inch inside to inside. *NOTE: Spring Fork are measured from lower triple tree to axle position. Universal fit for most Harley applications.
