Harley Big Twin Raw Machined Steel 41mm Fork Tube Set with 20 Total Length - V-Twin 24-0024 - OEM 45950-48
SKU 24-0024
$159.99
1599 ENTRIES 🎟️
$159.99 - $159.99
$159.99
1599 ENTRIES 🎟️
Raw machined steel fork tube is 20 inch stock length. Before installing compare old and new tubes. Be sure the stock top plug threads fit into the new fork tubes. Sold as a pair. *NOTE: These are fork tubes only. Order internals separately. Fits 1949-1976 Harley Panhead and Shovelhead models.
OEM #: 45950-48
  • Diameter: 41mm
  • Length: 20 inches
  • Drain assembly lube. We recommend 20 weight oil for average conditions. The amount of fork oil per leg is 6.5 ounces.
1949-1976 FL
