Harley Big Twin & Sportster Fork Stem Conversion Kit - V-Twin 24-1324 - Sportster 1937-1977
SKU 24-1324
$129.99
1299 ENTRIES 🎟️
$129.99 - $129.99
$129.99
1299 ENTRIES 🎟️
Fork stem conversion kit is used when installing a Big Twin or late Sportster 1 inch neck fork assembly on early Sportster models. Allows installation of Spring Forks with a 1 inch neck stem. Includes cups and tapered bearings for 1 inch fork stems to fit early Sportsters and 45 inch frames that originally had 7/8 inch fork stem. Remove your existing cups and install these cups into your frame neck and you are ready to install any 1 inch neck stem fork assembly. *NOTE: Order related spacers and nuts separately. **NOTE: Spacers can be installed on the underside of the neck for added height. Fits 1937-1977 Harley Sportster and Flathead models.
1937-1957 G
1937-1952 W
1957-1977 XL
