Harley Big Twin Chrome 41mm Fork Tube Set 22 Total Length - V-Twin 24-0401
SKU 24-0401
$189.99
1899 ENTRIES 🎟️
$189.99 - $189.99
$189.99
1899 ENTRIES 🎟️
Fork tube set is 2 inch over stock with a total length of 22 inch. Stock length is 20 inch. Tubes are precision machined with ground finish for fit and quality. Before installing compare old and new tubes. Be sure the stock top plug threads into the new fork tubes. Sold as a pair. *NOTE: These are fork tubes only. Order internals separately. Fits 1949-1976 Harley Panhead and Shovelhead models.
  • Diameter: 41mm
  • Length: 22 inches
  • Drain assembly lube. We recommend 20 weight oil for average conditions. The amount of fork oil per leg is 6.5 ounces.
1949-1976 FL
